Not starting
Old Apr 4, 2019 | 02:12 AM
  #21
CaBaRet's Avatar
Especially the breather pipes from the tank page 2-3 if thats block it could be all the problem that there is
Old Apr 4, 2019 | 02:30 AM
  #22
CaBaRet's Avatar
An easy fault finding one for this is when the bike wont restart open the fuel cap and if you get a whoosh sound then its building up a vacuum, unblock breather hose
Old Apr 4, 2019 | 02:46 AM
  #23
Dakota Davis's Avatar
Now air to fuel ... anyway to check that
Old Apr 4, 2019 | 02:49 AM
  #24
CaBaRet's Avatar
Do you mean Air to Fuel Ratio
Old Apr 4, 2019 | 03:55 AM
  #25
Yeah or something along that line
Old Apr 4, 2019 | 05:09 AM
  #26
CaBaRet's Avatar
Just popped out for some shopping, Yeh the Pilot Screw takes care of the Idle Mixture , (which is factory set) Main jet takes care of Higher Rpm along with the Needle Jet Slow jet in between (but they all work together for a smooth Transition) and Enrichment valves for cold starts
Old Apr 4, 2019 | 05:33 AM
  #27
So should that cause it to run one minute and not the next ... like I’ve tried 10x
Old Apr 4, 2019 | 05:39 AM
  #28
CaBaRet's Avatar
what might happen is ,if the Petrol Tank Breather pipe is blocked ,the pump will suck Fuel from the Tank as its needed, the Blockage sets up a Vacuum in the Tank and the pump cant suck any more, Try running the bike with the Tank Fuel Cap open ( at a standstill) if it cuts out again then its not a vacuum in the Tank causing the stoppage and we will look at something else)
Old Apr 4, 2019 | 07:25 AM
  #29
Ruff this damn thing.. wanna buy it .. I just don’t get how it ran good like really good until I shut it off and return like 5 minutes later and she hasn’t started since
Old Apr 4, 2019 | 07:35 AM
  #30
CaBaRet's Avatar
Stick with it matey, will it turn over or not start at all , quite a way to go till we figure it out
Ricebiker
Feb 26, 2017 09:21 PM
Timbostang
Nov 18, 2011 09:37 AM
wooferdog
Jan 12, 2011 05:00 AM
ryan_ashby
May 30, 2010 09:56 AM
tomstoy
Jun 15, 2009 08:01 PM
