NEED HELP !!shortage and stalling
Old Jan 14, 2009 | 10:04 PM
SHERLAND_88's Avatar
Default NEED HELP !!shortage and stalling
when i went to go start my f4 it over heated on me at idle with the choke on so i checked my fan and connection to my thermostat to see anything unusuall but found nothing so i checked my fuse box and foundmy fuse for the fan blown so i replaced it with another ond and so it popped that one too so i went and got a 15 amp fuse and put it in and for about 20 and then tyhe fuse for my cluster popped. so i took off my harness and took all the tape off and found no fault.
few hours prior to fuse poppin came up to a light and when light turned green i wen to go take off and then my bike just started to staulling out so i clutched it and throttled it a little more then it caught it self back up and when back to riding fine for 10 min till i got home.
Old Jan 14, 2009 | 10:51 PM
KLO's Avatar
KLO
Default RE: NEED HELP !!shortage and stalling
i had a similar situation with my bike except it had to deal with my fan not working. My thermo switch stopped working and it wouldn't turn on the fan.
I would be at the light, and if it got too hot, it would start to bog and stall out.
make sure your fan is working. i dont know about the shorting out though.
good luck with it and let us know what happened.
Old Jan 16, 2009 | 05:51 AM
yeah ok i was thinkin to change my harness and see what happens from there
Old Jan 20, 2009 | 03:28 PM
jonld's Avatar
Fuses blowing is caused by to much draw. That can be from a power wire going to ground or a faulty electrical component drawing to much juice. The Solution is never put a bigger fuse in, you'll just tear stuff up. The problem is likely your fan itself. when the bearings wear out the fan drags causing more draw on the system.
tmoore
F2 Tech
Nov 22, 2011 10:15 AM
lab4x4
Jun 12, 2008 11:37 AM
atr3yu baykor
Feb 6, 2008 05:55 PM
screamin cbr
Apr 25, 2007 06:41 PM
03CBR1k
Aug 1, 2006 06:56 AM
