need suggestion on pulling off carbs
Old Jan 20, 2009 | 12:32 PM
honda f4's Avatar
Default need suggestion on pulling off carbs
im in the process of pulling my carbs off the intake manifold and need suggestion or best way,
everything is loose and rocks back and forth i even tried using a pry bar but dont want to keep putting
pressure on my aluminum valve cover afraid it will crack , my ***** hurt ive been pulling so much
on those carbs any suggestions or ideas please!!!!!
Old Jan 20, 2009 | 12:54 PM
Seafordguy's Avatar
Default RE: need suggestion on pulling off carbs
They'll come. Just give 'em hell. I stood on top of my frame, and pulled from the top....
Old Jan 20, 2009 | 12:59 PM
honda f4's Avatar
can i use a pry bar i m afraid it will give and ill fall on my ***
Old Jan 20, 2009 | 02:33 PM
jonld's Avatar
If your setting as if your on the seat pull back and down and then push up and then just rock them till the pop out.
Old Jan 20, 2009 | 03:24 PM
honda f4's Avatar
thanks for the help my friends ill try tomorrow and let tou know how it goes im a little burned out for today!!!
Old Jan 20, 2009 | 04:58 PM
CB750's Avatar
If they've never been off before they are probably stuck to the rubber, it's best to start at one endand once you get that one going the rest will come off easier.
woody1121
Jul 29, 2015 06:28 AM
xXsquintyeyesXx
Jun 23, 2014 08:12 PM
Big Wheel
Jun 24, 2010 06:19 PM
SIRR1
Mar 30, 2009 09:10 PM
c0zgrove
Sep 3, 2007 01:19 PM
