Stalling Out
Old Nov 21, 2011 | 11:51 PM
tmoore's Avatar
Default Stalling Out
Here is the problem! Bike starts fine, I go to ride it and after about 2 miles it starts acting like it is not getting fuel. I pulled over and looked at the fuel line, it was not kinked. After sitting for about 2 or 3 minutes, I started the bike and it ran for 2 or 3 minutes and then stalled out again. Mind you, I am ridng it for these 2 or 3 minutes, at idle it runs fine.
Can anyone please help me???
Old Nov 22, 2011 | 08:11 AM
JankCibberf2's Avatar
umm, your air filter may be clogged? or leaking, your a/f screw may be improperly set, idk random shots in the dark
Old Nov 22, 2011 | 09:30 AM
74demon's Avatar
sounds like the fuel flow is too low. it's flowing enough to keep the carbs full enough for idle, but riding is draining them faster than they can fill. check your flow. i'd bet there is a restriction somewhere in the line or petcock.
Old Nov 22, 2011 | 10:12 AM
adrenalnjunky's Avatar
you do have the petcock rotated fully counter clockwise, and have a full tank of fuel I am assuming?
Might be time to pull the petcock assembly and check filter screens for clogging, and maybe test the petcock for flow rate.
Old Nov 22, 2011 | 10:15 AM
also - check your 2 tank vent lines, make sure they're not plugged/kinked. If the tank can't pull in air to replace the fluid being sucked by the carbs, it can create a vacuum that can overcome the pull of the carbs.
One other thing to check - carb boots - if you've serviced the carbs recently, make sure they're seated well and not leaking air. If you haven't looked at them in a while, make sure you dont have one that's cracked and sucking in extra air.
braddock112233
May 26, 2009 08:41 PM
lab4x4
Jun 12, 2008 11:37 AM
atr3yu baykor
Feb 6, 2008 05:55 PM
screamin cbr
Apr 25, 2007 06:41 PM
03CBR1k
Aug 1, 2006 06:56 AM
