IDLE AIR Mixture Screw
Old Nov 26, 2011 | 03:47 PM
TBJack2011's Avatar
Default IDLE AIR Mixture Screw
Hi guys,
So I was finally able to rebuild my petcock vavle and it works fine. My question is, which way u turn the idle air screw to make it run richer? I can't get it to start and I believe It maybe turned the wrong way. Any info would be really aprreciated.
Old Nov 26, 2011 | 04:29 PM
TBJack2011's Avatar
Its the screw next to fuel petcock vavle im talking about, just found its the throttle adjustment screw,if its turned the wrong way would it keep it rom starting.
Old Nov 26, 2011 | 10:07 PM
switched's Avatar
If i recall correctly, turning the screw clockwise will raise the idle speed. turning the screw counterclockwise will lower the idle speed. This is if you are looking directly at the top of the screw.
Hope that helps!
Old Nov 27, 2011 | 02:39 PM
TBJack2011's Avatar
K, Ill try that thanks
BlackMilk
Jun 3, 2013 03:01 AM
MikeInCtown
Aug 24, 2011 09:12 AM
rideoncbr
Oct 14, 2010 10:43 PM
duplago
Feb 22, 2009 10:45 PM
SJN
Apr 16, 2008 09:25 AM
