need help ! brake lights not working
Start with a volt meter. Is there power going into the switch? Is there power going out of the switch when it on? Remember, you need to have a good ground also from the light as well. Also, use the volt/ohm meter to check the new bulb. It wouldn't be the first new bulb that is bad.
Hayden06F4i
06-17-2008 09:50 AM
