my clutch arm is stuck after replacing clutches
Old Jun 27, 2023 | 04:52 AM
Hooligan1753's Avatar
Default my clutch arm is stuck after replacing clutches
Just replaced my clutch and clutch basket and now after putting the cover back on the clutch arm is stuck in position and won't allow my clutch to move what is the trick to getting the arm to line up with the lifter the proper way in order for it to allow it to work please help do not want to snap clutch lifter for the fourth time.
Old Jun 27, 2023 | 06:48 AM
Connella08's Avatar
when putting the clutch cover back on, stand on the throttle side of the bike facing the clutch basket. lightly put the cover back on the engine. point the clutch shaft so its at about the 8 o-clock position, then tap the cover on with your fist. the clutch shaft will move on its own as the cover slides on. when installed correctly, the clutch shaft will be pointed at about the 11 o-clock position at rest.
---------------------------clutch lever side------------------------------
------------------------------------12---------------------------------------
back of motorcycle -----------9------- 3---------- front of motorcycle
-------------------------------------6------------------------------------------
-----------------------------throttle side-----------------------------------
Old Jun 27, 2023 | 07:12 AM
Awesome I am about to go give it a try. I will update my status here shortly
Mark9
Sep 19, 2022 01:58 AM
Towlieee
How-To: Mechanical
Jun 11, 2018 11:03 PM
richardandrews
Mar 27, 2013 04:03 PM
dougcrx
Jan 18, 2012 04:26 PM
RyanEricW
Sep 8, 2010 11:34 AM
