1999 cbr 600 f4
Old Jul 1, 2023 | 04:35 PM
Tmartin8611's Avatar
Default 1999 cbr 600 f4
My 1999 cbr 600 f4 will not crank I replaced battery, jump solenoid starter good dash lights up full pump primes and a click from jump solenoid any ideal also tested the zener diode all is good
Old Jul 2, 2023 | 12:10 AM
dannoxyz's Avatar
Greetings & Salutations!!
1. what voltage do you measure into kill-switch?
2. kill-switch = RUN, measure voltage leaving kill-switch, volts = ???
3. voltage going into start-button = ??
4. press start-button, voltage leaving start-button = ??
5. press start-button; voltage at yel/red terminal at starter-solenoid = ???
This is 5-minute repair with multimeter. Or less in many cases
Old Jul 2, 2023 | 09:57 AM
rockpool's Avatar
Is it in gear with the sidestand down? Sidestand switch working? Neutral switch working?
smith
Nov 11, 2008 11:17 AM
