Largest front sprocket?
Old Dec 7, 2009 | 12:13 PM
BGm6er88's Avatar
Default Largest front sprocket?
Hey guys,
I currently have a -1 +3 setup and would like to get a +2 front sprocket for highway riding. Has anyone put a 18t front sprocket on? will it fit?
Old Dec 7, 2009 | 05:29 PM
Sprock's Avatar
Originally Posted by BGm6er88
Hey guys,
Doubt it will Dude I've got a CBR1000F with an 18 up front and had to
grind away the rear chain tab guide to get the clearance for the teeth.
The 18 gives great top end speed and lower rpm for Highway Runs which
all translates to a much smoother drive line.
Biggest I'm seeing for an F4 is a 17 ........and that's if you are running a
520 chain
LINK
Old Dec 9, 2009 | 01:58 AM
BGm6er88's Avatar
Thanks for the info!
Anyone have info specific to an F4?
Old Dec 9, 2009 | 02:02 AM
PlayfulGod's Avatar
you guys do know they make goldwings right??? lol
Old Dec 9, 2009 | 02:07 AM
BGm6er88's Avatar
like I said, im -1 +3 at the moment.. its almost unbearable riding at 80mph for any extended period of time. the +2 will bring me to just above stock for highway rides, and it can be changed in 5 mins.
Old Dec 9, 2009 | 10:55 AM
chuckbear's Avatar
Just keep in mind that using an old chain with a new sprocket is probably going to cause the new sprocket to wear more quickly if you're talking about switching these around a lot.
Old Dec 9, 2009 | 11:54 AM
BGm6er88's Avatar
Thanks. Yeah, i am aware of that. I'm not very concerned with it however since there will be relatively little time on the new bigger sprocket. the -1 +3 is also fairly new, so wear shouldn't be much of a concern.
Old Dec 11, 2009 | 09:08 AM
NCF4's Avatar
Its true, to go up on the front you have to do a 520 conversion. Which means new front and rear sprockets and a new 520 chain. It's also only offered in a 17 tooth (+1). Now, remember that going down one tooth on the front is equal to going up 3 on the rear. So, if you could do a +2 front with you +3 rear, it would be the same gearing as a stock rear, and a +1 front.
So call your local shop and give them these part numbers:
1212-0335 front 17 tooth 520 sprocket
1210-0268 rear 45 tooth 520 sprocket
LM520SOX120 520 chain, 120 links
depending on your states tax rate, it shouldn't cost you anymore than $130 for all three
segraves1
Jul 10, 2011 03:27 PM
91pusstang
Jan 7, 2009 04:22 PM
