Jerking while accelerating
So I took my bike to a shop for a carb rebuild, while the bike was there it developed a problem where it jerks while accelerating. This was not an issue before I took it there. The bike revs fine in neutral and idles fine, but now it jerks in every gear, and it feels like it has something to do with the engine. The chain was adjusted, spark plugs changed, compression test was good, crank sensor was tested, carbs are synced. He mentioned he messed with the wiring harness too and told me the problem is probably electrical. I also bought a carb sync tool and tested it myself, the carbs were synced but the vacuum was low, not sure if that would cause this specific issue though. And I’m brand new to working on bikes so any help is very much appreciated.
yeah so it completely died while I was trying to ride it to my friends house so his brother could look at it since he’s a motorcycle mechanic that specializes on Japanese bikes, pretty sure it was the fuel pump that crapped out. I’m thinking the fuel pump was on its last legs and that might’ve been the problem all along, I’ll come back with an update if a new pump doesn’t fix it
OK, keep in mind that carbureted motorcycles don't prime like fuel injected engines do. The fuel pump on these bikes only runs when the engine is being started or the engine is running. Let us know how it goes or if you need any additional help.
