HELP! starting problem!!
Old Mar 21, 2011 | 06:22 AM
kissel's Avatar
Default HELP! starting problem!!
so about a month ago i went out and started my bike. it had been sitting on a charger. started no problem. i hooked the charger back up and let it alone till i was ready to ride. this weekend i went out, unhooked the charger, tried turning the key and got nothing. no lights or anything. proceeded to jump the bike, which worked. but as soon as i disconnect the jumper cable the bike shuts off. WHY? any suggestions? thanks in advance!
Old Mar 21, 2011 | 12:14 PM
gotcbr's Avatar
How old is battery?
BTW, how are you jumping the battery? If using an automobile, never have the automobile's engine running.
Old Mar 22, 2011 | 08:05 PM
kissel's Avatar
yes using a car. not running the engine. was told that before by a friend but never knew the reason
Old Mar 22, 2011 | 08:06 PM
kissel's Avatar
battery is a year old at the most
Old Mar 22, 2011 | 08:11 PM
Bladed101's Avatar
Check your terminals for corrosion.
Old Mar 22, 2011 | 09:21 PM
brveagle's Avatar
Check positive and grounds for any loose/corroded wires
Old Mar 23, 2011 | 04:48 PM
kissel's Avatar
ifi have loose or corroded wires why would it work with the jumper cables hooked up? i feel like its a battery or alternator/stator problem...
Old Mar 24, 2011 | 12:09 PM
brveagle's Avatar
the alternator/stator is not your problem.
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
