Starting Problem HELP!!!
Old Apr 1, 2011 | 12:25 PM
dirtyhall's Avatar
Question Starting Problem HELP!!!
Bike: 2000 CBR600F4
Problem: Bike won't start. I recently moved and had to drain all fluids. Once I had time I added fluids back to the bike: antifreeze, oil, and gas. Put in the battery, keyed it on and heard a buzzing from the turn signal relay. When I pushed the start button, a buzzing/clicking came from the starter magnetic switch. I replaced both and still had the same problem. The bike was not turning over at all during this. I attempted a push start, didn't fire. But now it will turn over when I push the start button but it will only turn over once the the starter magnetic switch starts clicking loudly again. I pulled the plugs and pushed the start button, biked turned over with no problems. Reinstalled plugs and it's back to only turning over once.
Help please!!!
Old Apr 1, 2011 | 08:47 PM
polish man's Avatar
im by no means a bike expert but to me it sounds like a dead battery with the plugs out there would be no compression so it would be easier for it to turn over, just my thoughts
Old Apr 2, 2011 | 07:30 AM
Turbulenz's Avatar
Official Welcome Crew
when a starter solenoid clicks, there isnt enough voltage.. charge battery and repeat.
Old Apr 3, 2011 | 10:09 AM
dirtyhall's Avatar
It still does this with a jump box connected to the battery and directly to the battery cables and battery removed.
Old Apr 11, 2011 | 09:56 PM
dirtyhall's Avatar
Thanks people. Bought a new battery and it turns over now. But still won't start. Back fires a lot but won't fire.
Old Apr 12, 2011 | 10:06 AM
nickels's Avatar
I Can't Sell On CBRF
did you turn the petcock off when you were draining the gas check to see if the line is ran good too.....i believe i ran mine over the bar and back to the pump.
Old Apr 14, 2011 | 09:19 PM
dirtyhall's Avatar
I have turned the petcock every direction it can go and still not start.
Old Apr 15, 2011 | 08:41 AM
nickels's Avatar
it takes a minute for the fuel to catch. I remeber when i painted my tank i ran it out of fuel and it took more than a few cranks to get it started.
if its not starting i would pop the tank off and gravity feed fuel to the carbs. After that you will know if its fuel or not.
Assortedqtip
Jul 12, 2012 12:11 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
