headlight problem
Old Aug 6, 2013 | 11:32 PM
phantom_cbr600F4's Avatar
New Member
Default headlight problem
Hey everyone I'm new to the cbr world and am having a little trouble with my headlight. I have ohmed out the wires and they have good continiunity and there is voltage in the circuit however the headlight still will not come on. everything else on the clutch side of the bars like turn signals and the horn work just fine and all the fuses are good. the bulb is new just purchased two days ago if you have any idea of whats wrong with my bike or suggestions on what to look at it would be greatly appricated. thanks
Old Aug 7, 2013 | 10:09 AM
Fryup2000's Avatar
Perhaps your headlight switch is naff?
Old Aug 8, 2013 | 02:06 AM
New Member
what dose naff mean? im new to the whole forum thing if you could explain that would be greatly appricated.
Old Aug 8, 2013 | 05:12 PM
Black'n'Yellow's Avatar
Hi,
There's several definitions for "naff" and here are some of them :
Urban Dictionary: Naff
What Fryup2000 is try to say is it' s broken,faulty,non working
If the switch is broken then there will be no circuit so that and the bulb are usually the first place to start.
I would check these first and take to a local shop or friend with experience if you can't work it out.
Old Aug 8, 2013 | 08:39 PM
CJardine's Avatar
Track junkie & modaholic
you might be out of blinker fluid.
Old Aug 8, 2013 | 08:52 PM
New Member
is there any way someone can post a good wiring diagram? I work on cars for a living and should be able to figure this out if I have all the right tools for the job. thanks for all the advice so far the switch checked out good from what I know however I cant be for sure with out a goo diagram to go off of.
Old Aug 8, 2013 | 08:53 PM
New Member
lol or my muffler bearings are bad
Old Aug 12, 2013 | 09:43 PM
New Member
problem is fixed thanks for all the advice in the end i just hard wired it to the battery and put a fuse in on the wire to keep from draining the battery
Old Aug 13, 2013 | 01:38 AM
CJardine's Avatar
well I can give you a pic of a wiring diagram if you still want it, hell I have a link to download the service manual as well.
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
josemiguel
Oct 20, 2007 09:06 PM
