f4 running rough at steady speed.
Old Aug 27, 2008 | 10:01 PM
lilbcollins's Avatar
Default f4 running rough at steady speed.
1999 with 25000 miles, just cleaned carbs, they are spotless slides all move really well with no sticking, sync'd the carbs, no vacuum leaks. Bike runs awesome when your on the throttle, but throttle response is weak and seems to sputter a little bit at steady cruise. New ngk plugs, old ones had perfect burn on em, k&n in the box, and a d&d slip on, carbs are jetted plus 1..
Any ideas?
Old Aug 28, 2008 | 03:48 PM
murtagh's Avatar
Default RE: f4 running rough at steady speed.
I had my bike run like crap at random speeds and then I charged the battery to full and it all went away. Don't know if this is your problem just one of the ones I had when my bike was acting like that.
Old Sep 20, 2008 | 01:02 PM
usmarine6211's Avatar
My bike is doing the same thing. Did you find anything out with your bike?? Shoot me your solution if ya did. Thanks alot!!
Old Sep 20, 2008 | 01:30 PM
jonld's Avatar
Do a charging system test. Mine did that when the regulator was going out. Also at 25k have you checked the valve clearances yet?
12stones
May 20, 2019 03:37 PM
Tort93f2
Apr 13, 2012 12:18 PM
drmmrguy28
F2 Tech
Aug 8, 2010 04:47 PM
HELIGUY02
Sep 25, 2009 05:15 AM
Ralph
Jul 27, 2009 06:36 PM
