Engine identification help
Old Nov 2, 2008 | 01:46 AM
BlenderHead's Avatar
Default Engine identification help
I've got a cbr 600 (engine only, I don't have the bike) in a formula sae car that some students designed and I'm not sure what year it is, or if it's an F4 or F4i. I need some help identifying it. I've been told it's an F4i, but i've also been told it's a 1999, but did they make the F4i in 1999? or did that model come later?
Basically I was wondering if anyone could tell me if there are any identifying marks on the engine that would tell me what year/model it is.
Thanks in advance, all help is appreciated.
Old Nov 2, 2008 | 07:43 AM
Nauree's Avatar
Default RE: Engine identification help
need pictures
Old Nov 2, 2008 | 10:37 AM
Seafordguy's Avatar
They didn't make the F4i in 1999 - only the F4.
F4i's are fuel injected if that helps at all
Old Nov 3, 2008 | 11:59 PM
ORIGINAL: Seafordguy
Thank you, that does help actually.
Based on this, I'm pretty sure it's an F4, not an F4i.
Old Nov 4, 2008 | 07:54 AM
jonld's Avatar
if its carbureted and it is for sure and f4 series then it is '99-'00, Fuel injection would be '01-'06. They are all f4's but only the '01-'06 are f4i's.
Old Nov 5, 2008 | 02:26 AM
thanks, it has some student-designed aftermarket fuel injection on it, though i suspect it was originally carbureted, but since the original carbs or fuel inj. is no longer there, i cant really be sure
Old Nov 5, 2008 | 10:44 AM
jonld's Avatar
have you pulled the valve cover off? if so the f4i has a cam pulse sensor on the exhaust cam opposite the gear. The f4 does not.
Old Nov 6, 2008 | 12:12 AM
thanks, i'll check that out
lilryan
Apr 10, 2013 01:21 AM
Kieme
Aug 14, 2011 08:35 AM
kawasakiklx
Jun 22, 2010 06:58 PM
username
Mar 18, 2007 05:55 PM
mcle6658
Dec 22, 2005 10:19 AM
