Engine cut off problem @ Idle
Old Apr 14, 2008 | 09:59 AM
dannydoo's Avatar
Default Engine cut off problem @ Idle
Hi,
I purchased F4 a month ago. It is my first bike.
I noticed a problem while idling when engine is cold. Not a big deal but it bugs me.
When I start the engine, idle is kind of rough like it's not getting enough power.
It gets smoother in about a min as engine gets warmer.
But the problem is when the idle is rough on that first 10~20 sec, when I pull the throttle, engine just dies.
When its gets warmer and idle gets smoother after like 1~2min, I can rev it up without a problem. It only happens within that first 30 sec.
Is this normal?
Old Apr 14, 2008 | 10:05 AM
yafayu's Avatar
Default RE: Engine cut off problem @ Idle
Did you turn the choke on...?
Old Apr 14, 2008 | 10:11 AM
dannydoo's Avatar
ORIGINAL: yafayu
Yes. This is while the chock was on.
Old Apr 14, 2008 | 01:20 PM
f2kboost's Avatar
If u have the bike not running for long periods then yes its normal to see the bike not staying on when in idle or idleing rough...in that situation i set my bike on choke and then start it..leave it on choke for bout a minute or two and then turn it off..bike runs fine on idle.
Old Apr 14, 2008 | 01:27 PM
dannydoo's Avatar
ORIGINAL: f2kboost
ohh ok. Thanks for the tip!
By the way, I only ride on the weekend so it is basically not running for 5~6days. Is that considered to be long periods?
Old Apr 14, 2008 | 02:58 PM
f2kboost's Avatar
yes thats definitely a long period
Old Apr 14, 2008 | 03:55 PM
dannydoo's Avatar
Thanks for the great info f2kboost
Old Apr 14, 2008 | 06:55 PM
f2kboost's Avatar
ORIGINAL: dannydoo
no problem
Old Apr 14, 2008 | 09:04 PM
saetneta's Avatar
A good rule of thumb is to let it warm up (full choke) until you see the temp indicator hit the C mark -- then your bike will probably we perfect by the time you get out of the driveway.
tomekzski
Mar 20, 2014 11:07 PM
fernnny
Oct 31, 2013 07:51 AM
Hootie233
Aug 10, 2010 08:55 PM
SwedishPhish
Feb 24, 2010 09:37 PM
super600
Sep 30, 2009 08:22 PM
