Cbr600f4 won't start
Old Jun 3, 2024 | 08:35 AM
Diego18901's Avatar
Default Cbr600f4 won't start
As the title said my cbr600f4 won't start,
A backstory: i was riding in may on tuesday i think 80 miles or 130 km. No problem, i was riding 2 days later for half an hour no problem, yet i started the bike 3 hours after without a problem was riding to a friend and while in idle trying to connect our sena, it shut off.
Of course we tried to start it and heard a strong crank, and sometimes obvious compression. We called ANWB(dutch triple A) and after half an hour later it started, we shut it off and started it succesfully. Yet when i tried to put it in first(as i thought it might have fluked for a while) it shut off again, ANWB came 1 hour after and it turned on using a jump battery. I was even riding for about 3 mins going trough all the gears, no problem. Yet when i was in idle it was fine, but we tried to give some neutral gas and fell out again.
soo we don't think it was our compression or starter. I was waiting on parts and just got around to working on it. I charged the battery in the mean time. I installed new spark plugs tested the coils. It had the all clear. I installed a new pump and new fuel line and filter. I drained my tank filtered the gasoline.
So what else could it be?
​​​​​​My guesses:
-relay/fuse
-carb
Any help is appreciated
Old Jun 3, 2024 | 01:51 PM
dannoxyz's Avatar
​​​​​​My guesses:
-relay/fuse
-carb
This is caused by safety-interloc circuit. Imagine coming to stop at junction with clutch squeezed. Then you put kickstand down, what happens? Igniter kills engine!
Measure all your safety switches: neutral, clutch and sidestand switches along with their wiring.
Old Jun 9, 2024 | 09:26 AM
Diego18901's Avatar
Well i just finished the rounds, i could hear crank from the starter but again it wouldn't start up, i some times heard compression but it wouldn't start up. I rebuild the carb, new fuel lines, new pump. tested the safety switches, nothing
Old Jun 9, 2024 | 09:35 AM
dannoxyz's Avatar
Yes can measure status of switches at wires on computer connector. Due to AND/OR logic circuitry that combines multiple switches into one wire, you won’t know which switch is bad. Often is loose bolt holding switch that allows misalignment and switch won’t activate properly.
Old Jun 9, 2024 | 09:47 AM
Diego18901's Avatar
A quick answer thank you but unfortunately the switches are "unfortunately" working
Old Jun 10, 2024 | 11:22 AM
dannoxyz's Avatar
Then wiring between switches and ecu connector is broken.
Do test for spark. Do you get spark when cranking?
Old Aug 21, 2024 | 04:09 PM
Diego18901's Avatar
I am sorry Dannoxyz, I lost acces to my gmail for a while so I couldn't answer you as i keep forgetting my password but it was stored on my google.
anyhow, yes i got spark when crank the engine, i am indeed also thinking of buying a new cdi or at least checking the wiring as i see it is a common issue, how do i check if it is my CDI or wiring.
thank you in advance
Old Oct 5, 2024 | 03:54 PM
Diego18901's Avatar
soo while I was still waiting on the fuel pump(back order but I canceled it eventually) I decided to get in contact with a mechanic.
he told me that this happened a few times, and that most of the time it was because of a safety issue, with a sensitive positive cable. I ordered a power probe and I will test it as soon as the new pump gets in.
also after waiting for the fuel pump I got to research on another fuel pump and I got recommended the facet 40171 pump and in specs it it basically a perfect replacement. do I need to do something before I can install this pump.
born2rideanF4i
May 15, 2008 01:07 PM
shizz
Mar 26, 2008 02:47 AM
sox0804
Jan 26, 2008 07:29 PM
spudmn439
Sep 15, 2006 02:03 AM
gixxereater
Jul 30, 2006 04:35 AM
