brake problem
Old May 18, 2005 | 02:39 AM
bgoode11's Avatar
Default brake problem
so this f4 i recently bought has a problem with the braking. when i apply the front brake i get a shimmy in the front end. kind of feels like a pulsation from a warped rotor. any suggestions on what to check? i dont want to go buy new rotors and have that not solve the problem. can anyone suggest anything? thanks
Old May 18, 2005 | 07:38 AM
Marinko's Avatar
Default RE: brake problem
You can put a dial indicator onto the bike and spin the wheel while the pin sits on the disc. You don't want to have a high amount of run out. If you do there are not many people that will even attempt to machine the disc so the only option will be to change the disc. You can try running some sand paper on both pad and disc. To see if there is a small difference when reassembled and braking but if the discs is warped this will be fruitless.
Old May 18, 2005 | 09:11 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Ditto what Marinko said. If a rotor is warped it'll send a helluva pulse through the brake lever when stopping from high speeds. You can check to make sure the caliper bolts are tight and that the pads still have life but I'd say from your description that the rotors are warped.
Old May 18, 2005 | 04:15 PM
bgoode11's Avatar
thanks guys, how many thousanths of an inch maximum runout do you think i should have before it will be felt?
Old May 18, 2005 | 07:15 PM
Brake disc max runout on the 1000RR is 12 thousandths. Don't know how much it'd take before you felt it through the lever.
Old May 19, 2005 | 01:50 AM
bgoode11's Avatar
thanks for the help guys i'll measure my runout and see what happens
kellybarrs
May 18, 2010 07:53 AM
riegnman
Jul 11, 2008 11:14 AM
bigz954
Jul 2, 2008 12:10 AM
Chunky
Nov 8, 2007 08:51 AM
dominiksi
Mar 23, 2007 12:38 AM
