BLINKERS
Old Jun 13, 2006 | 06:00 PM
ddvs's Avatar
Default BLINKERS
Ok, so I have aftermarket rear blinkers, but there is a big problem, my right side blinks twice as fast as the left side. What is going on?
Old Jun 13, 2006 | 09:05 PM
Angryviking's Avatar
Default RE: BLINKERS
LED or regular bulbs?
Legend has it you need an inline box to make LEDs blink right.
If it's 2 regular bulbs, make sure they are rated exactly the same. (40w and 40w ?)
Otherwise, I'm outta ideas...
Old Jun 14, 2006 | 04:10 PM
ddvs's Avatar
I am pretty sure they are regular lights not LED's, the top of them are carbon fiber but I can't see inside the blinker itself to see the bulb, they are aftermarket.
Old Jun 14, 2006 | 10:53 PM
There has got to be a way to replace the bulb if needed. Otherwise, they may be non-replaceable LED.
Old Jun 15, 2006 | 04:29 PM
ddvs's Avatar
Viking, I don't think the lightbulbs are causing the problem, I think it has to do with something else, maybe the wiring or the way he installed the lights?
Old Jun 15, 2006 | 04:33 PM
2 wires per blinker, ground and positive. I suppose if those are mixed up that could cause a blink rate problem. Usually it's a change in the draw on that circuit.
sunny
Feb 23, 2011 11:30 AM
shrtbus
Nov 29, 2008 02:21 PM
FosmoenAlex
May 2, 2008 10:15 PM
Slipspace
Jul 28, 2006 08:42 PM
