Airbox Question
Old Mar 3, 2010 | 12:26 AM
gsxr1000nutcase's Avatar
Default Airbox Question
if you take the screws out, and remove the cover, and then take out the inner screws, pull out the two pieces, there are two foam pad/foam filters, how important are these? none of my gsxr's had this, and when i removed them for cleaning the airbox, one of them tore, can they just be removed, i cant find new ones to buy
Old Mar 3, 2010 | 09:25 AM
2000F4's Avatar
If your talking about the actual air filter, I would say thats pretty important unless you feel like sucking whatever flies into the ram air tubes right into the engine. Plus the extra airflow would most likely make you have to rejet. Just order an air filter off eBay or right from Honda.
Old Mar 3, 2010 | 11:14 AM
jonld's Avatar
He's not talking about the actual air filter as his post clearly describes. Those pre-filter the crank vent tubes to help keep oil out of the breather box. I removed mine long ago with no side effects. If you want to replace them the OEM part number is 17226-MBW-000
Old Mar 4, 2010 | 02:13 AM
cool thanks man, im just going to toss-em for now
Old Mar 4, 2010 | 08:05 AM
jonld's Avatar
That's what i did, though if you wanted you could get some of that universal filter material from any bike shop or small engine shop and cut a couple pieces down to size.
Old Mar 6, 2010 | 01:17 PM
ya i might do that some day, the bike is running good now, tossed the foam filters!!
Treesquid
CBR1000F Wanted / Swap
Dec 2, 2009 11:13 PM
hypeshipe
Jan 20, 2009 07:22 PM
4ebypek
Jan 5, 2007 12:31 PM
neva non profit
Apr 6, 2006 07:17 PM
shraz
Dec 30, 2005 12:44 PM
