airbox sensor question
Old Dec 29, 2005 | 05:54 PM
shraz's Avatar
Default airbox sensor question
I changed my air filter and was looking at the sensor... HOW DOES THIS THING WORK?
it looks like a cone with no hole at the end... how does it measure the amount of air?
also what's the best way to put back the tank
I always take 30min to put it back together because of the bolts that don't align right, especially in the front, its always too short so I have to push the tank hard infront to try to align them but sometimes doesnt work. I found putting the bolts infront first than rear is a little bit easier.
Old Dec 29, 2005 | 06:52 PM
Tahoe SC's Avatar
Default RE: airbox sensor question
dunno about the sensor, just let it be mang!
as far as the tank, don't tighten it up all the way, just the the threads in there first and then once they're all in tighten it.
Old Dec 29, 2005 | 07:07 PM
chainstretcher's Avatar
Admin Emeritus & MVN
ORIGINAL: shraz
FM my friend -- just like all the electronic gadgetry -- FM
Old Dec 29, 2005 | 07:12 PM
doncollins's Avatar
Retired Administrator
Which sensor are you talking about?
You have the following and the name kind of explain them:
MAP (manifold absolute pressure) sensor
TP (throttle position) sensor
IAT (intake air temperature) sensor
ECT (engine coolant temperature) sensor.
[IMG]local://upfiles/1936/9B85069BD41040BAA7609A39165127F7.jpg[/IMG]
[IMG]local://upfiles/1936/ACC29A740FD94C6597F820776EB8DEB3.jpg[/IMG]
[IMG]local://upfiles/1936/5A3FD6E47A38436DA6FDD9FD8D1454E8.jpg[/IMG]
[IMG]local://upfiles/1936/797ACE8F8A5744F99E29AB0BE1510C3F.jpg[/IMG]
Old Dec 29, 2005 | 07:13 PM
doncollins's Avatar
ORIGINAL: chainstretcher
ORIGINAL: shraz
Am I the only one that's going to get this.... FM = fairy magic.
Old Dec 29, 2005 | 09:24 PM
03954guy's Avatar
the sensor is the iat intake air temperature sensor it doesnt measure volume of air that is the map sensors job basically what it does is calculates air density based on temp ( from iat ) and inputs from the map sensor
Old Dec 29, 2005 | 09:29 PM
03954guy's Avatar
this is an air box from a 2002 f4i if you are talking about the sensor at the top kinda in the middle that is the iat
[IMG]local://upfiles/2233/EFE89FA408F04E07AD8EB080A9107E22.jpg[/IMG]
Old Dec 29, 2005 | 10:02 PM
I thought MAP was manifold air pressure?
Old Dec 29, 2005 | 10:20 PM
thirdgenlxi's Avatar
Ironmang
Old Dec 29, 2005 | 11:15 PM
Ya, that's it!! If you don't have enough check valves a turbo will destroy it -- not a cheap sensor ... don't ask how I know ...
