yet another problem..help
ok well assuming my regulator is whats causin the bike to spaz out, i went on ebay and purchased a regulator from another f3(def has to b aftermarket)..i get a new batt.. go home n turn the bike on..all is well but i have no brake lights, no low beam headlight, and is it normal for the regulator to be REALLY hot just after about 2mins of idle??? oh and yes the fuses are fine.. WAIT!! and...when i put the bike in first, it stalled??? weird?
The Regulators on F3's run very hot, which is why they fail so easily.
also if it stalled when you put it in first was the kickstand down, cause you cannot go into gear with the stand down, it will shut the bike off.
If you stand was up check that the sensor is ok and not telling the bike you stand is down when it is not.
dewthedoo05
Sep 4, 2007 09:32 PM
