Would you recommend replacing the cam chain?
I've been trying to figure that one out also, when I changed mine to manual I just went hand tight, then started the bike and slow cranked it down to where bike didn't make noise threw all rpm range. Its worked so far but I know there has to be another (true) way to do it.
was reading this post and I'm having the same problem. I replaced the cctl with the factory one and still have the rattle was going to try the manual cctl, but I ran my bike out of oil as you said so I was wondering if it was worth trying the manual one?
if the cctl needs tightening, what type of noise does it produce? just recently, when cruising around on mid rpm's, i started hearing a "fluttering" sounds, that in best comparison kinda sounds like an exhaust leak, coming from the front/right front of the bike..it seems to do it only under load. and ive felt around but cant feel escaping exhaust..does this sound like a cctl that needs tightening?
