Would you recommend replacing the cam chain?
on
I have a co-worker just bought an F3 with around 20K miles. He is insistant on replacing the cam chain, thinking it is stretched. But, I am insuring him the aftermarket CCT will tighten it up and no need to go through the entire trouble of replacing the chain.
Here is the question; has anyone heard of the chain stretching or breaking to cause any engine problems on a F3?
It would be highly unlikely for a 20k bike to have worn out the cam-chain.
It rides in an oil-bath in a sealed environment.
Now 20k IS time to have the valves run-out. Money is better spent on that
task. I guess while you are there you could inspect it, if it's a cause for concern.
Same for the CCT.
Ern
Same for the CCT.
Ern
If he thinks the noise is from a bad chain, he's going to be disappointed when it's changed and still making noise. As everyone is saying, it's the CCT. I usually go with the OEM CCT because it's a install it and forget it. The manual will have to have the tension set correctly once installed.
