wierd vibration
Old May 8, 2007 | 01:44 AM
lookinout's Avatar
Default wierd vibration
question for the f3 folks while cruzing say 35 and up i can feel a vibration coming from the motor.
when i pull my clutch ina little bit just befor it slips the vibration goes away i had my tires re ballanced replaced chain and sprokets oil change ect.. im wondering if its clutch time or motor is going south
i have gone through the manual but no luck yet any imput would be great
thanks in advance!!
Old May 8, 2007 | 02:30 AM
LlanoSV's Avatar
Default RE: wierd vibration
what gear are you in?
also do you have the bar ends on. I've heard that without them you can geel a lot more vibration.
Old May 8, 2007 | 11:37 AM
KidCr3nshaw's Avatar
Maybe a twisted frame? I've seen people check them (on the net and TV), but I honestly wouldn't know how to go about doing it.
If it's coming from the engine area (underneath you), I would say a twisted frame or broken motor mount/s...
Good luck, that sucks.
Old May 8, 2007 | 12:46 PM
Northernfirepower's Avatar
When your going at this 35mph just let go of the bars...if they start to wabble then you should check out your front end. I am missing a bar end and I can't tell any diffrence, but I "do" have bent rotors and that will make my bars tank slap when I let go. Just look at your calapers when your going and see if theyr moving in and out or not.
Old May 8, 2007 | 10:10 PM
lookinout's Avatar
i do have bar ends i took them off just to try to see if somthing changes i picked up a little more vibration
but nothing to write home about as for speed and gear it dosnt matter the same issues are still there
the bike has never layed down so i dont know about the bent frame thing and thanks kid i didnt think about the motor mount thing i just checked andtheir ok so still scratching my head in this one
thanks for the imput guys!!
Old May 12, 2007 | 10:23 AM
ceeber6's Avatar
carbs may need balancing mate?
Old May 12, 2007 | 03:26 PM
LlanoSV's Avatar
Did you try the riding with no hands at 35MPH? Check that,
Also is it a violant vibration? or just a small vibration? Is it affecting your cornering or affecting going straight?
Old May 13, 2007 | 02:24 PM
lookinout's Avatar
thanks for all the help as it turns out i needed a new clutch at 19500 miles thought it would last a little longer than that but hey its cheap and easy to fix the new clutch is in now and no more vibes
thanks all.....
Old May 13, 2007 | 09:50 PM
pacemaker's Avatar
The hands off approach, I've had a slight wobble with my bike with hands off bars from new, yet no problems with handling at all. wobble with hands off bars can be anything from fork & rear suspension adustment, tyre balance & tyre wear & steering head bearings.
hawkwind
The Hurricane Saloon
Sep 3, 2009 11:31 PM
focus01
Oct 2, 2008 08:46 PM
fiveoh
Feb 9, 2008 04:52 PM
camoweasel
Jul 2, 2007 03:11 PM
bikesnjeeps
Mar 13, 2006 07:34 PM
