what did i get myself into! "new" 95 cbr600
Old Jun 7, 2011 | 06:13 AM
  #41
sharkm87's Avatar
are you sure its getting fuel?... mine died on me while goin to work, turned out the fuel pump went.. so i took it out and connected a small line straight from gas tank and by passed fuel pump
Old Jun 7, 2011 | 07:05 AM
  #42
detroitcbr's Avatar
Originally Posted by sharkm87
sounds like the bike is in gear
It was lol I'm still so new to this!
  #43
detroitcbr's Avatar
Ill try this as soon as my battery comes in
Old Jun 7, 2011 | 07:17 AM
  #44
sharkm87's Avatar
lol... i dont wanna sound like a deuche.. but it may be benneficial to you to take the msf rider coarse... i learned alot there
but we all start somewhere..
Old Jun 7, 2011 | 08:02 AM
  #45
Will.Bass's Avatar
It has spark I pulled the plug out and ground it to the bike its sparking
ok? and? you know you have spark. did you pull all 4? i suggested a very quick and simple way to test for fuel...did you try it? did it start up? i think you may be seeing past what i said..if you spray staring fluid in the intake of your "non-running" engine, and it starts, the you know you are NOT getting gas and then you can start your troubleshooting
Old Jun 7, 2011 | 08:14 AM
  #46
Will.Bass's Avatar
Another strange note, the front brake is now locked up unless i have the clutch in???
+1 lol.
Old Jun 7, 2011 | 08:31 AM
  #47
Mrmanr's Avatar
Try cranking it without tank and airbox on. Just connect a bottle of fuel. That way you can see into velocity stacks to see if you are getting gas.
Old Jun 11, 2011 | 09:43 AM
  #48
OK, it's Saturday and it's been a few days. How are you getting on ? Any progress ? You should be able to tell if you've got fuel getting to the carburetors by opening the bowl drain screws slightly to see if there is fuel. Also, since you had the carbs apart, it's possible the idle is set too low for the engine to run. Try turning it in 1 full (360) turn. Are you using the choke ?
Old Jun 11, 2011 | 06:44 PM
  #49
detroitcbr's Avatar
Update: battery came, I did a 2nd much more thorough Carb clean while I was waiting, the bike fired right up with a couple sprays of starter fluid but I ran out of time to reattach the gas tank, and I want to reclean it first anyway. Hopefully more to update tomorrow!
Old Jun 11, 2011 | 10:00 PM
  #50
Sounds like we're making some serious progress here... keep it coming. It's all good.
