tyre pressures
Old Nov 22, 2008 | 01:31 AM
flstc's Avatar
Default tyre pressures
really sorry asking some dumb questions while i try and open a "zipped" manual. here goes . what is the recommended tyre pressuresfront and back for a 1997.tks also curious about the colour scheme of white, red and purple. someone told me that it was a limited edition. did i mention that this bike is sooo much fun !
Old Nov 22, 2008 | 04:01 AM
pacemaker's Avatar
Default RE: tyre pressures
36 PSI front 42 PSI rear
Old Nov 22, 2008 | 08:55 AM
bigjohnstud4200's Avatar
Pics?
Old Nov 22, 2008 | 03:03 PM
flstc's Avatar
if it stops raining i'll take one and post. opened the manual so i wll spend some time today having a browse.
ORIGINAL: bigjohnstud4200
Pics?
Old Nov 22, 2008 | 05:27 PM
justasquid's Avatar
Just keep in mind the recommended tire pressure is for max load. If your not maxing your bike out, you can run less pressure. If your not a corner carving nut yet, then running the max pressure will be ok. Its only when you start getting better on corners that you should lower the pressure to get better traction. I currently run around 32 rear 30 front and my bike is happy there. Just remember every bike is different and likes different pressures. one or two pounds of pressure can make or break a bikes handling when you start pushing it.
Hudson
Aug 13, 2012 03:57 PM
sawnee
Mar 23, 2009 03:31 PM
JeremyGSU
Aug 10, 2008 12:47 AM
Coopz
Jul 13, 2008 08:28 PM
mozza847
Aug 24, 2006 11:28 PM
