Tyre pressures...
Old Jul 11, 2008 | 02:39 AM
Coopz's Avatar
Default Tyre pressures...
Just wondering if my tyres deflate at a normal rate. My last bike was a R1200GS and I only had to check the tyres once every 3-4 months and even then they only dropped 4-5 psi. With the CBR I have not ridden it for about 2 weeks and have not tested the tyres for just over a month, back was a soft 16psi and the front was 32, the backs supposed to be at 42... If I ride it regulary it will probably be on about 20 in 1 months time.
Just crurious if this is acceptable? The tyres are only 5-6 months old as well.
Old Jul 11, 2008 | 02:46 AM
Shadow's Avatar
Default RE: Tyre pressures...
Mine deflate too, but not that fast - maybe 2-3 PSI in a month. I fitted those valve covers that tell you if they're dropping pressure - what a bargain. I run at 2.8 bar/R, 2.6 bar/F (41/38psi)
Maybe your tyre's not seating properly on the rims, or there's valve leakage ?
Old Jul 11, 2008 | 06:28 AM
cb2cbr's Avatar
If your tire air pressure loss is more than 5psi/month it's not normal. I'd go looking for that leak. It's slow enough that it might be tough to find. A pump spray of soapy water might reveal it, start at the valve. If no luck, Pull the wheel and put in a shallow tub of water, rotate it around till you find it. Sing "Tiny Bubbles" as you go. Good luck.
Old Jul 12, 2008 | 06:57 AM
BLUE1000F's Avatar
My tyre pressure was still the same after the winter storage this spring.Checked it before a trackday about a month ago and it was still the same.I don't think it's "normal" at all when the tyres leak air/pressure...
Old Jul 13, 2008 | 08:28 PM
bluebeard's Avatar
All tyres leak some air but 20+ psi in a month is waaay too much. Not dangerous if you watch it closely but I would be finding the cause asap.
Hudson
Aug 13, 2012 03:57 PM
sawnee
Mar 23, 2009 03:31 PM
flstc
Nov 22, 2008 05:27 PM
JeremyGSU
Aug 10, 2008 12:47 AM
mozza847
Aug 24, 2006 11:28 PM
