Trying to do air bypass but missing hoses
Old Mar 13, 2012 | 12:14 AM
JLAvila's Avatar
Default Trying to do air bypass but missing hoses
So I just bought this baby the other day. It doesnt start but it does turn over nicely. I have tried few things but just ran into a snag doing an Air Solenoid Bypass. I tried doing it and found out that I am missing a ton of rubber tubes and have no idea if air is still getting into the carbs. So on the diagram, the last tube I have is number 10 and everything else is just gone. I have attached some pictures and I just want to know what I can do and if this can be why the bike wont start. I was taking the fairings off today and like 2 rubber tubes just fell out but they are not the same diameter as the ones I know of missing.
Old Mar 13, 2012 | 04:11 PM
Although you probably do want to put the hoses back on, you could remove all of them and the bike would still start up and idle. I think I'd be looking in the area of fuel and spark. Pull a spark plug and see if you're getting a good spark, and check to see if you've got fuel in the carburetors by opening each of the drain plugs to see if fuel comes out.
Old Mar 16, 2012 | 05:06 AM
LilRed F3's Avatar
I have a CA spec bike and have everything hooked up till the #11 hose and everything works like swiss watch. You should be good in my opinion as long as all the hoses are plumbed into the air box and carbs.
Old Jul 12, 2012 | 10:20 PM
IanCBR600F3's Avatar
Hey I have a CA bike too. You mean you left everything but from hose 11 forward?
amRRussel
F2 Tech
Mar 11, 2016 05:09 PM
kiwi JK
The Hurricane Saloon
Jun 12, 2011 11:06 PM
Kuroshio
Jul 27, 2009 08:44 PM
ThatIsSosteve
How-To: Mechanical
Jul 22, 2008 05:56 PM
01slvrf4i
May 23, 2007 04:51 PM
