Throttle Position Sensor - Must I Use?
Old 08-25-2010, 11:38 AM
rothjl749's Avatar
Default Throttle Position Sensor - Must I Use?
I have an F3 motor in an F2 frame and the TPS sensor does not allow the carburetors to be installed properly. I am wondering if there is any way around this problem? Also, what would be the downfall of eliminating it totally?
Thanks,
Josh
Old 08-25-2010, 06:07 PM
I think it depends on whose ICM you're using. If you're using one off an F3, then you need that TPS. It helps with determining ignition timing. If not, then you could probably get away without it.
Old 08-26-2010, 07:13 AM
rothjl749's Avatar
So, if I wanted to benefit from ignition timing without the TPS, I would need something like a Dyna2000 or something similar?
SixHundo
07-31-2019 10:44 PM
intiractive
01-08-2012 09:03 AM
Evilbugster
01-25-2010 03:58 AM
mxseven
04-23-2009 06:34 AM
evandensmore954
12-17-2007 09:39 PM
Quick Reply: Throttle Position Sensor - Must I Use?
