Throttle position sensor wires
Hi
Can anyone tell me what wires are what, in the throttle sensor on a carb engine. I presume there is a negative, a input voltage and a output signal voltage and the electrical diagram agrees as it says you have:
yelow/blue
blue/green
yellow/red
I have read the manual and it says that the inspection adaptor has the following wires but not what they attach to above.
green
red
white
Cheers
yelow/blue
blue/green
yellow/red
green
red
white
Cheers
Buddy has an 08 m1000 and he;s getting the ecu07 code im pretty sure thats the code And it says on the airbox its the throttle position sensor...but a new throttle position sensor is over 400 at the local dealer. Any suggestions? The sled only has about 250 miles and it all stock with a can.Thanks
