taking carbs off 95 f3
Old 07-19-2009, 07:51 AM
Dissevered's Avatar
Originally Posted by Kuroshio
Bout to start this myself tomorrow but I've got a question: What cleaner to use?
Hitting Pepboys and Autozone yield cleaners appropriate for cars. But I'm concerned about the diaphrams and floats. Is there a single cleaner good for both? Or what do yall recommend for the floats and diaphrams?
You shouldn't need to clean the floats or diaphragms unless you got some serious crud and old carbs that sat for 2 years. IF you need to then try that seafoam stuff, I never used it so I can't give opinions. For actual jets and anything metal, carb cleaner works very well too. Just don't get it on your gaskets or diaphragms.
  #22
Old 07-23-2009, 10:17 PM
drosas12's Avatar
okay guys. I pulled off the spark plugs and was oil fouled w/ corrosion.
I know there is probably some serious engine problem but don't have the money to get into yet and buy parts.
So I am just cleaning/sanding the spark plugs.
Any other things I should check. My starting problem may be related to the plugs
Uniqsol
03-05-2010 07:36 PM
adenney
08-04-2007 02:17 AM
slvr600RR
04-29-2006 07:11 AM
Quick Reply: taking carbs off 95 f3
