Swapping Chain Help!
Old Aug 24, 2008 | 08:15 PM
jojackson's Avatar
Default Swapping Chain Help!
I've got everything off, but my drive sprocket. Which way do I turn it? is it reverse or normal threads? also, is it safe to put it in 1st gear to hold the sprocket?
Old Aug 24, 2008 | 08:51 PM
Coug68's Avatar
Default RE: Swapping Chain Help!
Normal thread, use an impact to loosen if you have one.
Old Aug 24, 2008 | 09:53 PM
Normal threads, counter-clockwise to remove. If you don't have an impact wrench, no worries. Put the bike in 6th gear, have someone press on the rear brake. You'll then be able to remove the bolt with no problem. Putting the bike in 6th gear gives you the greatest mechanical advantage between the rotation of the sprocket and the engine.
Old Oct 5, 2008 | 01:55 AM
SLORider18's Avatar
or just put a pipe over the breaker bar for more leverage with the bike in gear and the rear brake on. oh, you should loosen it before you take the chain off.
Old Oct 5, 2008 | 05:16 PM
I sure hope he's gotten it off by now , but it's a nice thought.
stunt it f1
Oct 11, 2009 09:15 AM
TrIkKeDoUtF4I
Jun 13, 2007 08:48 PM
TrIkKeDoUtF4I
Jun 13, 2007 06:43 PM
sparg93
May 11, 2007 10:40 AM
Junior
Oct 24, 2006 06:31 PM
