swapping everything
Old Oct 9, 2009 | 06:00 PM
stunt it f1's Avatar
Default swapping everything
does anyone know what all modifacations are needed to put a 1998 f3 swing arm and 1993 f2 forks on my cane?
Old Oct 9, 2009 | 06:39 PM
Red_Eye's Avatar
Most Honda forks should be a straight swap if they come complete with the triples, other forks will not fit your F1 triples. Not sure about the swingarm, I'm guessing it's probably undoable without some major machine shop/fabricating skills. Using a VFR single sided swingarm would be easier, but still a major project AFAIK.
Old Oct 10, 2009 | 06:13 PM
how can i get a wider tire without swapping swingarms?
Old Oct 10, 2009 | 08:15 PM
Red_Eye's Avatar
Honestly, the easiest way would be to just sell the F1 and get a newer bike. I don't think you can fit any thing wider than a 160 in the stock swingarm, and like I said a swinger swap is not a small project.
Here's a project log than involves putting an RR swingarm on a '96 F3, which probably already has a wider swingarm than an F1. Even with his fabrication skills, the guy still had to pay a machinist to custom make bushings to make it fit:
http://www.customfighters.com/forums...ad.php?t=16273
Old Oct 11, 2009 | 01:07 AM
my back tire is currently a 130, a 160 would be nice how would i do that?and u said the f2 forks would just be a straight swap if came complete?
Old Oct 11, 2009 | 09:15 AM
Red_Eye's Avatar
160 will fit on the stock wheel and swingarm, but it won't fit nicely. Most Hondas use the same size steering stem, so if you have a complete front end it will just bolt on. So you'd need the calipers and front wheel along with the F2 forks. Look in the classifieds or salvage yards for wrecked bikes for parts, I just got an 05 F4i without a motor for $200. I'll be putting the front end on my F1 this winter.
Raymond
Jul 27, 2009 08:49 AM
akaseman121
Jun 29, 2009 09:48 PM
Ian
Jun 28, 2009 06:37 PM
stynkmonkey
Mar 24, 2008 07:28 PM
Junior
Oct 24, 2006 06:31 PM
