Suspension settings/sticker
Old 03-09-2011, 08:45 PM
frunko1's Avatar
Default Suspension settings/sticker
This has been bugging me for a while, the stickers aren't lined up the same on the fork nuts on one the arrow is lined up with the fat part, the other it is lined up with the skinny part. The bike rides well enough, but was just wondering if every ones is like this.
Old 03-09-2011, 08:56 PM
jbrandona`'s Avatar
Mine aren't that uneven, but they aren't lined up or anything.
I was going to adjust them, but I'm not really sure what the sag should be.
Old 03-09-2011, 09:45 PM
scorpionvmu's Avatar
2011 Ride of the Year
i think they both should be aligned with the pin hole notches and adjusted from there to what kind of ride you want (hard or soft)
Old 03-10-2011, 12:01 PM
s10camaro's Avatar
Uh....Guys, he's talking about the stickers on the fork nut not the adjustment nut itself.
I will take a look at mine after work.
Old 03-10-2011, 12:59 PM
DrAwkwArD's Avatar
That sticker will turn as you adjust preload.
Is this a serious question?
That sticker will rotate if you change the preload. Have you set up your front suspension for your weight yet? If not, do it....the orientation of the stickers doesn't matter at all. Adjust your preload and they will change.
I fell like I'm getting trolled.
Old 03-10-2011, 04:05 PM
frunko1's Avatar
I am talking about the sticker placement on the nut,
one side is
other side is
The stickers aren't consistently placed on the nut.
Edit
cbr600f3-1.jpg?t=1299795089
Added lines to show better what I am talking about
nuts face different directions but stickers face the same
Old 03-10-2011, 04:13 PM
DrAwkwArD's Avatar
one side is
other side is
It really doesn't matter...the nut can be turned...so the stickers might never line up.
But check your preload. That's how the sticker gets turned around. But again, it doesn't matter how the sticker is oriented if your preload is correct.
Make sense? I don't know how else to explain it, I'm sorry.
Old 03-10-2011, 04:23 PM
they are all like this, both in different direction.
Foxtrot4India
03-30-2009 05:29 PM
mm2565
02-19-2007 02:17 AM
Thorsome
10-24-2006 09:02 PM
CBR BoyRacer
09-19-2006 10:16 PM
NotSoMellowYellow
04-25-2006 09:29 AM
Quick Reply: Suspension settings/sticker
