Suspension settings/sticker
This has been bugging me for a while, the stickers aren't lined up the same on the fork nuts on one the arrow is lined up with the fat part, the other it is lined up with the skinny part. The bike rides well enough, but was just wondering if every ones is like this.
I was going to adjust them, but I'm not really sure what the sag should be.
That sticker will turn as you adjust preload.
Is this a serious question?
That sticker will rotate if you change the preload. Have you set up your front suspension for your weight yet? If not, do it....the orientation of the stickers doesn't matter at all. Adjust your preload and they will change.
I fell like I'm getting trolled.
one side is
other side is
The stickers aren't consistently placed on the nut.
Edit
cbr600f3-1.jpg?t=1299795089
Added lines to show better what I am talking about
nuts face different directions but stickers face the same
But check your preload. That's how the sticker gets turned around. But again, it doesn't matter how the sticker is oriented if your preload is correct.
Make sense? I don't know how else to explain it, I'm sorry.
