suspension adjustment
Old 07-09-2007, 02:06 PM
ptowntsi's Avatar
Default suspension adjustment
is there anyone that is around 180-200lbs on the forum so i can just my suspension the same as you? sometimes on bumpy roads i'm getting a lot of oscillations/feedback from the bumps. Not sure if it is too soft causing it to sink and have the bump but it feels like my compression is too stiff.
Old 07-09-2007, 03:14 PM
KidCr3nshaw's Avatar
Default RE: suspension adjustment
F3, right? My front is a bit softer than factory, 3 visable rings on the preload, and 7 clicks out from full in on the rebound.
Couldn't tell you about the rear, I know the spring itself is on 4 I believe and the canister I've never touched.
I'm 6' 204lbs.and my bike handles like it's on rails. I've gone through various front setups and haven't touched it since I got it where it is.
Old 07-12-2007, 11:56 AM
Here are my settings (I'm about 190lbs). These gives me a firm butstill comfortable ride with plenty of feedback, and accurate steering. The bike is mainly used on twisty, bumpy back roads:
Front Preload: two rings showing
Front Rebound: 1/2 turn out from full in
Rear Preload: 4
Rear Rebound & Compression: 1/2 turn out from full in
Woot, my first post!
Old 07-14-2007, 01:51 PM
HAVOC's Avatar
just go out and ride and adjust your setting a lil bit each time. copying someone elses settings might give you a ok starting point but whats good for one person might feel awful to you. its all about trial and error. also id read up on some suspension articles and get a good idea what each adjustment does and you'll be on the right path
Old 07-14-2007, 02:02 PM
how do you adjust the rear pre-load???? To be honest I have never even looked at mine - I know the front set-up is standard I am 6ft and about 188lbs
Old 07-15-2007, 01:47 AM
Can you run through how to adjust the front and rear suspention. Just a quick reference. Like socket size, and what to look for when setting it up. Thanks
Old 07-15-2007, 03:07 AM
ORIGINAL: ptowntsi
I'm about 200-207...and my F2 is about the same as your F3.
Front forks:
Pre-compression damping: 2 seams or lines showing.
Compression damping: (Th one you could djust with a dime if you had to) One turn out from full hard/all the way in...
Rear suspension:
Rear Spring Preload:
The spanner adjusted to 6...just short of full stiff.
Rebound damping:
One full turn out from full hard.
Compresssion damping:
One full turn out from max.
Get the F4i manual at stephy's site...the controls are the same, though the F4 has more adjustments.
Old 07-15-2007, 01:31 PM
blkpitbull's Avatar
Im about 210, and like my F3 this setting.
Front forks have 10w fork oil.
preload at 3 lines showing
rebound at 1/2 turn out from full stiff (all the eay in)
Rear preload at setting #7
compression at 1/2 turn out from full stiff
BTW bmg velocitythe adjustment on top of the frok is rebound not compression. You cant adjust compression on these forks!
The following users liked this post:
Lukasg97 (07-31-2024)
scastillo13
04-08-2009 08:19 AM
krobberts
03-28-2008 01:18 AM
vkhamphi
07-04-2007 11:00 PM
wxgsr77
04-05-2007 03:59 AM
demat
08-26-2005 11:33 PM
Quick Reply: suspension adjustment
