Steering Dampers?
Whether you get use out of it depends on how you ride. It reduces front wheel shake that comes from riding at very high speeds. I suppose if you do a lot of high speed wheelies it could reduce the chances of a tank slapper if you set the wheel down wrong. Other than that, you would probably be just wasting your money.
You're taking off with the throttle WAY open, and it's making the front end of your bike lift off the ground. That's not "bounce problems," head shakes, or tank slapping, it's perfectly normal for what you're doing to the bike. If you don't want it to do that, then try taking off from the line appropriately. You're throwing too much power to the back end from a dead stop, and inertia is causing the chain to pull the entire weight of the bike upwards by the front sprocket, and then once you start moving, it does this more lightly, and bounces it off the asphalt a few times. Doesn't sound like anythign I'd do some somethign I care about and spent a lot of money on.
In your case, a steering dampener is just going to reduce the shock that gets sent through your arms. Your bike will still bounce, and you will still be slamming all the important stuff at the front end of your bike against the ground. .
As the old doctor said: "Then stop doing that."
If you're constantly riding on crappy roads, then yeah.
I'm wondering if you have a more serious problem going on. Your bike should not be doing that unless you're hitting some serious bumps. How many miles do your chain and sprockets have on them? It sounds like they might be catching. When's the last time you lubed?
Could be crappy suspension too. Suspension upgrades will help take care of bumpy roads way better than a steering damper will. Some people even think the built in Dampers on 600RRs are overkill because 600's are not fast enough. Usually Dampers are for serious high speed head shake. Your problem is either just related to suspension or throttle control.
But, if you want one real bad, then the only brand I ever hear about is ohlins, so I am not of much help as to what brand is good for the f3.
