starting running problem
Old Sep 30, 2008 | 10:04 PM
st3veo89's Avatar
Default starting running problem
ok i posted a post earlier as help!! to refresh my bike wont start after sitting for a couple hours it will crank strong til the battery dies i jump it and after about 15 min of solid cranking the bike starts runs and drives if i shut it off and ten min later start it it starts up fine sometimes the idle jumps up and down and lately when im riding when i give it full throttle it sputters really bad but when i hold in the clutch it revs just fine i took the carbs off and cleaned them still does it this problem just came up before when i bought the bike it didnt have an air filter on it about a week before i got a k and n it started doing this put the air filter on it still does it i need help asap thanks!!! i bought a new fuel pump and coils havent gotten them yet but could either be the problem?? or could my timing itself be off?? or could my jets be clogged either way im prolly gonna get a stage 2 jet but maybe it could be the timing??
Old Oct 1, 2008 | 09:55 AM
redzintimidator's Avatar
Default RE: starting running problem
did you clean the jets when you cleaned the carbs??...thats the most important part it does sound like that, or a carb synchronization problem
Old Oct 1, 2008 | 10:19 AM
st3veo89's Avatar
ok so how do i go about cleaning out the jets??
armyman2988
Jun 28, 2010 05:42 PM
benji1174
May 26, 2010 02:48 PM
entity-unknown
Mar 20, 2009 11:55 AM
lowlif3
Oct 13, 2008 02:17 PM
meeson01
Oct 4, 2008 06:04 PM
