Starting Problems with my F3
Ok I finally got my f3 back on the road. It runs great but the only problem that I have now is that when Itry to start my bike it does not start up right away. I have to play with it for a second and sometimes that wears my battery down or sometimes it seems like the battery is not strong enough to start it! Once I get it running all is well and it cranks up just fine after it run about 5 or 10 minutes .I just want to be able to hop on that bad boy and go. If you have any suggestions I am all ears this Forum got my bike back on the road so I am turning to it once again!
FYI It has a brand new battery
I'm having similar issues with mine at the moment... but my plugs are three years old. I have plugs to put in... it's just sooo damn cold out there. My situation is that after the bike it warmed up and then shut off, it won't start up.I think that I've also got an air leak some where in the intake because when I try to start it again (temp gauge is above first mark),my biekacts like it'sflooded. I've also been thinking of syncing the carbs since they have never been touched ever since I've had the bike... and I rode it off the show room floor. Tighten up the bands in between the carbs and manifold and also check the rest of the air intake for any potential air leaks.
