sprocket noise?
Old Apr 17, 2009 | 11:25 AM
obie84's Avatar
Default sprocket noise?
i have this noise coming from my front sprocket. i had a mechanic look at it and he said he doesnt think that it is the sprocket. he said the sprocket is a little bit worn but not to the point where it should be making a noise like that. the chain looks good and so does the rear sprocket. it started making this noise after i was riding home one night and the chain had losened up a little bit. thanks for reading any advice will be greatly appreiated.
Old Apr 19, 2009 | 11:38 AM
A few things can cause chain and sprocket noise. Worn sprockets (which you say they're not), loose chain, impropperly aligned rear wheel and sprocket. A loose chain can cause excessive noise. Check your manual for proper slack settings. What type of noise is it ? When do you hear it ? Idling, low speed, high speed ?
Old Apr 19, 2009 | 08:38 PM
ominous1's Avatar
so does a chain thats too tight.
Old Apr 20, 2009 | 05:20 AM
obie84's Avatar
i hear the bike anytime the bike is moving. the bike can be running and not moving but no noise. if the bike is off and i am pushing the noise is there. thankyou for your help
Old Apr 20, 2009 | 06:19 AM
pacemaker's Avatar
Like the others have suggested, check you chain for tightness & rear wheel alignment & lube the chain at the same time. Chains never wear evenly, so even when adjusted correctly (always adjust the chain at its tightest point) You will get noise as the tight & loose sections of the chain go over the sprockets. Even on a new(ish) chain you will get some noise.
Old Apr 20, 2009 | 01:25 PM
pontyhufc's Avatar
i had a squeaking noise coming from the front sprocket last week and after a new set of tires it was gone so i can only see that it was the rear wheel alignment that was off.
Old Apr 20, 2009 | 02:42 PM
gangofhoes's Avatar
I had the same problem, and making the chain just a bit tighter fixed it right up
kaska
Jun 6, 2011 12:32 PM
woodypk
May 2, 2011 05:21 PM
hamburgler
Jun 15, 2009 01:29 AM
christhek
Aug 1, 2006 10:12 PM
