Weird noise in sprocket area
Old Dec 25, 2008 | 04:06 AM
kaska's Avatar
Default Weird noise in sprocket area
Happy holidays!
At the end of the last season i got new interesting symptoms on my hurricane.
A humming or howling noise coming from countershaft sprocet area.
The noise started around 60-70 kph and went on until the wind noise killed it for me
I have looked some blueprints and thought about it a while and as much as i know only thing that can make that sound is worn bearing on countershaft next to output sprocet.
Now have enyone ever had to deal something like this?
I am thinking to take the bike apart during the long season and still hoping to do this while the engine is on frame, alltough this time i dont believe it is possible
So have enyone took apart the hurricanes crancase and have any good pointers?
Old Dec 25, 2008 | 04:38 AM
94cbr600kid's Avatar
Default RE: Weird noise in sprocet area
just another question..Are you sure its not coming from your chain like your chain is loose?
Old Dec 25, 2008 | 06:16 AM
Shadow's Avatar
Check sprockets and chain for wear, as suggested. Clean and recoat chain with oil/wax.
I'd do that before checking anything else. A faulty wheel bearing/out of line wheel could cause the chain to be running offline - any offline running could cause a howling such as you describe.
Check the cheap options first, Kaspar !
Old Dec 25, 2008 | 06:35 AM
kaska's Avatar
the chain and sprocets are new, driven less than 1500km.
I noticed the problem first when i had tighten the chain a bit too much and loaded bike heavily. Thats because i tought i made too much axial force to bearing and it wore out. alltough as i looked the haynes manual at least 600 model has 6004 bearing in there which is the same as in front wheel so that is prettty good hard duty bearing and should not be so gentle.
Classic what do you mean by checking the countershaft adjustment?
The next step i am going to do, which is the first one also, is to remove the chain and trying with hand, can i shake the countershaft.
The pictures are mustbe anyway in my case as i am photographer
and Pete i try to start with the cheaper things at first
Old Dec 25, 2008 | 08:40 AM
kaska's Avatar
Yes i know the balancer, but i dont think it can be it. Cos the problem is not related to engines rpm. I think its related to real output shaft speed. If i made a test on centerstand with whatever gear i accelerated and when the speed hits around 60-70kph the sound begins and still goes on even though the engine is idled. I tried on higher speeds also and it is still there even at 200kph - i did not dare to go any further speeds on centerstand
The whatever gear rules pretty much out a wore out gear srpocets in my mind so i tought i should be a bearing of outputshaft ???
Old Dec 25, 2008 | 11:47 AM
kaska's Avatar
Well by hand i did not make out any axial movement at all. Altough the sprocet on shaft did wiggle ( shake, move) a bit - is this normal?
The noise appeared soon after changing the sprocets and chain. And the front sprocet is 16 so not original?
I have not dealed with this kind of sprocets before, on russian made bikes the fasteners of sprocets where a bit different[&:]
Old Dec 25, 2008 | 12:16 PM
R1000's Avatar
ORIGINAL: kaska
Yes it is normal on the CBR 1000 F that the sprocket is floating; this is to ensure it will not unscrew the sprocket bolt. Stock front sprocket is 17 T.
Did the noise disappeared for a while after changing sprockets and chain?
Old Dec 25, 2008 | 12:35 PM
kaska's Avatar
Before changing them there where no noise.
But now much must it float. about 2 mm on mine case - isnt it too much?
