Shifting question problem?
Old Oct 23, 2011 | 07:24 PM
72tx340's Avatar
Default Shifting question problem?
Today was the first day i got to ride my bike any distance. I found a couple of times the bike didnt want to down shift it seemed to be locked in top gear. This happened twice during my ride. I had to almost come to a complete stop before i could down shift. Any ideas on what could be causing this? When should the clutch ingauge off the handel bar. I notice mine is quite a ways out before the clutch grabs. Not sure if its adjusted right.
Old Oct 23, 2011 | 08:40 PM
74demon's Avatar
it should be about 1 inch or so. you can adjust it a little tighter or looser, depending on the feel you like. sounds like your cable not adjusted right. tighten it just to the point there is no free play, then back it off a little. you will notice about an inch on either side of the lever travel. fine tune as you see fit.
Old Oct 24, 2011 | 01:04 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
this can happen when you come to a complete stop from higher gears and try and shift (while the bike is sitting still) back into first,
however normally simply shifting down while moving the bike backwards (or forwards) at the light about a foot or so should allow the gears to shift into place.
if this is what you are talking about i suggest down shifting when you are coming into a stop instead of stopping in a higher gear at a light before shifting still.
romanboy
Apr 29, 2012 01:01 PM
Atrom
May 11, 2011 05:21 PM
HKchucksta
Oct 6, 2009 06:36 PM
neonlights
Sep 27, 2008 06:24 AM
alpinestarz
Jul 17, 2006 10:49 PM
