Shifting into second
Old Apr 14, 2010 | 04:42 AM
justasquid's Avatar
Pretty normal for lazy shifting.. No offense. What I mean is, 1st to 2nd is skipping over neutral, so it requires a bit firmer shift when compared to the other gears. A lot of times, you don't even realize your shifting too soft until it doesn't go into gear, or it pops back out.
If your riding in shoes, I'd suggest buying a set of riding boots. That can make a huge difference in your shifting. You will put more force into the shifter without more effort on your part as the boots have a much harder top surface that doesn't deflect like a pair of shoes will when shifting.
Old Apr 14, 2010 | 08:34 AM
chuckbear's Avatar
+1
Old Apr 14, 2010 | 09:12 AM
Michaud85's Avatar
yeeah i did notice a big difference when i wear my steel toe work boots u can always give it a nice firm shift
Old Apr 14, 2010 | 10:16 AM
johnnyx's Avatar
Man, I didn't even think of that. DUH. Have you adjusted your shifter height? I'm so used to troubleshooting broken stuff that I forget to address the basic setup questions.
I still think its a worn gear, though, as shifter height would affect ALL upper gears, not just second.
Old Apr 15, 2010 | 03:20 AM
bobmilkman's Avatar
Also make sure you are preloading (putting pressure on the shifter) before you let off the gas or tap the clutch. I find that if I don't do this on my bike, I will miss the 1 -> 2 shift about a third of the time.
rell123456
Aug 6, 2014 01:37 PM
Measuredpath
Jun 25, 2009 03:03 PM
riekky
Jul 15, 2007 07:03 PM
KidCr3nshaw
Oct 18, 2006 07:10 PM
mr tone
Sep 25, 2006 10:10 PM
