Seafoam Use
Old Sep 17, 2008 | 12:12 PM
kjohnson's Avatar
Default RE: Seafoam Use
The only thing you need to do to the oil is use an OEM filter.These bikes have good oil flow.
As for Seafoam,I like it.But only use it periodically if the bike sits.
Old Sep 17, 2008 | 01:40 PM
soccer13pro2007's Avatar
nah, forget OEM filter check this http://motorcycleinfo.calsci.com/Fil...tml#OilFilters I got the Pure One PL14610, have yet to change my oil, but it was cheap, supposed to be real good, etc.
Old Sep 17, 2008 | 06:03 PM
kjohnson's Avatar
OEM oil filters have more paper than all the others.
Old Sep 17, 2008 | 11:11 PM
*blinks incredulously*
You didnt even take a look at that article did you?
The pure one had 110 square inches where the OEM only had 94
Old Sep 18, 2008 | 02:55 AM
kamikaze2899's Avatar
I usually use seafoam to help get the carbon buildup off of the valves. Direct through the carbs with engine running, pour it in until the motor dies/floods out. Let it sit for about half an hour. The start it up. It will smoke ALOT. Keep the RPM up until it cleans out.
northern if you want to do this in your car, you can pull the vacuum hose off of your master cylinder and pour it in through there. Just dump it in until the engine stalls. Let it sit then start her up.
Your neighbors will hate you though. The smoke is thick and smelly.
Old Sep 18, 2008 | 07:28 AM
kjohnson's Avatar
ORIGINAL: soccer13pro2007
Believe all you want from bogus write-ups like that.My mechanic is an AMA SS &SB mechanic(or DMG,depending on one's view) and we cut open several of those ourselves and found that the OEMs use more paper than all others (Fram,K&N,Purolator etc etc).
Old Sep 18, 2008 | 07:37 AM
Northernfirepower's Avatar
ORIGINAL: kamikaze2899
LOL, I'll have to look into doing that [sm=badbadbad.gif]
dad0507
Sep 3, 2014 06:59 AM
hikeetech
Sep 28, 2012 04:32 PM
RudyGT
Aug 31, 2012 08:57 PM
ZBike
Apr 7, 2012 11:51 AM
TimBucTwo
Mar 15, 2012 11:59 AM
