ride issues
Old Aug 22, 2008 | 04:10 PM
soccer13pro2007's Avatar
Default ride issues
Now that Ive got my F3 running well, I have only a few issues with it.
First of all, the fork seems bent in some way. When Im riding straight, my hanglebars are cocked to the right, and its not just handle placement, the actual fork plate is cocked too. Is there some way to fix this??
Secondly, being that Im a newer rider, I still have to find the clutch feel, which is VERY difficult on stop turns. Should I straighten my wheel and wait until I begin moving to turn or turn the wheel and try moving from there? (the throttle was a LOT more difficult that way and I made an *** out of myself putting feet down outside of a gas station, haha) I'm used to driving a manual car, and i can let the clutch out and mix gas flawlessly so there's no engine rev, learning on the bike, I fear I'm going to have to have some rev, is that too bad for it?
Old Aug 22, 2008 | 06:25 PM
MrBomb's Avatar
Default RE: ride issues
for the fork issue, sounds to me like you have a bent fork, you can just take the front end apart and check them, if one is bent you may be able tostraighten it out on a press or just have to get a new tube
for the stopped turns, its definitely easier to start going and then make the turn, it takes a while to get the feel of the clutch and twist throttle but once you get it it will be no problem for you
hindsey123
May 9, 2013 06:44 PM
Turbulenz
Mar 9, 2010 12:42 PM
munro88
Mar 7, 2010 06:20 AM
thirdgenlxi
May 18, 2009 01:24 AM
blkwolfcbr
Sep 22, 2006 06:39 AM
