Remove jet needle
Old Aug 25, 2010 | 11:46 AM
NAP2AZ's Avatar
Default Remove jet needle
directions says use one the diaphram screws in the middle and gently pull out. Well mine ain't budge'n. I looked up the diagram and clearly it should come out of the slide retainer.
just to clarify also included with the kit was a drill bit and stated to drill the two outer holes around the needle. My ? Is do I drill to the same depth as the oem??
there's my two bitches!
Old Aug 25, 2010 | 12:41 PM
kerosene's Avatar
I took a screwdriver and pryed it up
Old Aug 25, 2010 | 12:44 PM
NAP2AZ's Avatar
Small flat head around the slide retainer? Maybe some penetrating oil would help?? I tried all 4 pulling on them but didn't want to damage th cause it's a pretty delicate part
Old Aug 25, 2010 | 01:37 PM
96@cbr's Avatar
no no no no!! put the screw that came off the cap. get some pliers and use some elbow grease and yank it out. your not going to break anything
Old Aug 25, 2010 | 05:49 PM
Put one of the screws that came off the diaphram cover into this hole. Screw it in about 1/4" to 1/2". Then with a pair of plyers, pull on the screw and it will remove that black round post along with the Jet Needle. It is only held in place by a "O" Ring sitting in a groove in the bottom. It will come out.
Old Aug 25, 2010 | 06:57 PM
NAP2AZ's Avatar
Apperciate the advice. My new chain should be in tomo so I will tear it all down again.
WhiteHawk
Jun 5, 2013 07:47 PM
Mbennett
Mar 6, 2013 07:16 AM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
tmj1000rr
Mar 26, 2007 06:11 PM
