which regulator/rectifier is best to use?
Old May 1, 2010 | 02:37 PM
KRUSHER F3's Avatar
Checked the a/c voltage from the stator and it was below 50 volts so I'm changing the stator out with the other one I have. When I took the stator off there was a alot of oil inside the cover, should that be in there or could that be part of my problem?
Like I said earlier I did lay it down on that side a little over a week ago. When I stood it back up It wouldn't do nothing so I let it set there while I was checking on my buddy that went down too. After mine sat there for a while then it cranked right up with no problem.
Old May 1, 2010 | 03:14 PM
Shadow's Avatar
there was a a lot of oil inside the cover,
They do run in oil I think. Maybe a seal has gone and there's too much oil. Not sure
Maybe a teaspoon full or two, is about what I have in my stator.....
Old May 1, 2010 | 03:20 PM
KRUSHER F3's Avatar
not this much I would assume. coul that much effect the stator?
Old May 1, 2010 | 03:32 PM
Shadow's Avatar
I'm not sure whether it would or not but I'd have the seals looked at - it SEEMS a bit much but some bikes run more than others. My 1000F doesn't have anywhere near that much, as I recall.
Old May 1, 2010 | 03:49 PM
KRUSHER F3's Avatar
Like I said though, I laid it down on that side. When I stood it back up It wouldn't do nothing so I let it set there.
Old May 1, 2010 | 08:18 PM
KRUSHER F3's Avatar
well got the stator changed out and checked the voltages across the battery again and here are the results of the two:
ENGINE TEMP/RPM...........OTHER STATOR..............THIS STATOR
cold Idle 1100 to 1500------12.49 volts-------------12.36 volts
cold 2500 RPM-------------13.16 volts--------------12.98 volts
cold 5000 RPM-------------12.57 volts--------------14.20 volts
hot 1100 to 1500 RPM-----12.50 volts--------------12.26 volts
hot 2500 RPM-------------12.82 volts--------------12.45 volts
hot 5000 RPM-------------13.60 volts--------------13.25 volts
Not much difference between the two stators. I checked both for resistance they were the same checked for the a/c voltage coming out of each stator wire, the same (forgot to write them down but were all 3 consistent) So based on this information my charging system I would say is working properly, all I need to do is replace the R/R.
Anyone agree or disagree? opinions?
Old May 3, 2010 | 12:13 AM
Honda933's Avatar
Originally Posted by IDoDirt
The nice thing about a Stator is that there is not much too it and it's easy to check with a meter. To test with a meter, you just measure ohms (resistance) across any 2 of the yellow wires that are in the connector that go to the R/R. The connector needs to be unplugged and the ingnition turned off. The proper value to read would be 0.1 - 1.0 Ohms. That is a very low reading, but remember that it's just a coil of wire. Make checks across all 3 combinations of the yellow wires. If any of them read outside of the specification, then you should replace it.
I'm currently using GSX/R regulators on both my F3's. The original on my F3 melted, and the other I just replaced as a precautionary measure.
thank you very much
Old Apr 14, 2019 | 08:56 AM
Smoking joe's Avatar
Default 3 stator
does it matter that the f3 has a wet stator aand the gsxr stators are not?
cwcbr91
Oct 20, 2020 09:16 AM
gnuwolf
Aug 13, 2008 01:10 AM
nograv1
Jul 16, 2008 04:17 PM
Rican X
Mar 19, 2008 12:12 AM
jv1964
Dec 4, 2007 08:24 PM
