Rear wheel periodic rubbing
Old 03-16-2013, 12:48 AM
Sascacuan378's Avatar
Default Rear wheel periodic rubbing
So I'm a total idiot and last time I adjusted my chain I forgot to loosen my axle nut first. After doing this I was riding a little and pulled over and dropped the kickstand without putting it in neutral first. The bike gave a lurch and shut off. After starting it up again, I started getting the periodic rubbing noise that's typically associated with a warn bearing or warped rotor. But I had the bearings and rotor looked at recently and they should be good. I'm convinced the wheel moved slightly out of straight from being jerked on the left side when the engine lurched. Is it possible that this would have shifted the bearing slightly or bent the rotor?
Thanks!
Old 03-16-2013, 12:53 PM
I was right. The right side of the wheel was 0.5mm further back than the left side, and the rotor was rubbing.
pookguy88
07-12-2012 09:08 PM
hitman66
06-19-2011 05:43 PM
BigMike0147
11-30-2008 10:54 AM
sanders1977
06-17-2006 05:49 PM
sanders1977
01-12-2006 10:40 PM
Quick Reply: Rear wheel periodic rubbing
