rear plasticks seperating
any one have the problem with the rear plasticks seperating from the middle plastick behind the seat is there a real good fix for that ... its done it since bike was new i replaced the middle part once already cause one if the **** that hold the side rear plastick to it broke off ... if i get a aftermarket rear set up for it thats one peace how will it work?
RE: rear plasticks seperating
That is the down fall to the three piece tail end. I hate it when I look back there and see that they are "blown" apart and I think... how long have I been riding like that? I know there are some after market tail pieces that can be purchased which are one piece. Down side to after market is theydon't always fit as well as OEM. Check out the rubber garments in your sub frame where the tail pieces push into. I have replaced them a couple and has seemed to reduce the occurrences of the tail pieces from separating.
When I had a crack in my front fairing what I did was bought a fiber glass patch kit from my boating store and patched the crack with that. That repair seems to be the strongest thing. I wonder if it would work with making your tail one piece. For now I just use clear packing tape on mine. That way it can only be seen if your looking right at it.
berga
F2 Tech
03-25-2010 09:11 PM
